first image
Add Note Step 37 — Top Shield
  • Your laptop should look approximately like this.
first image
Add Note Step 38
  • Remove the following 14 screws (some models may be missing a couple of screws):
    • One 2.5 mm Phillips.
    • Six 3.5 mm Phillips.
    • One 4.5 mm Phillips near the sleep light with a small shaft.
    • Two 4.5 mm Phillips with larger shafts.
    • Four 6 mm Phillips.
first image
Add Note Step 39
  • Peel back three strips of yellow tape in the bottom left corner.
  • Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
Add NoteNotes: Step 38
Flag Reply by neato Nov 7 @ 8:11 PM
If your iBook is like mine (700MHz) The yellow screw was attached from the bottom through the bottom case and had to be removed earlier in order to remove the bottom case. Also the the green screw pictured to the left was missing already removed.
