Replacing Motorola V60c Keypad and Keypad Logic Board
Markup Problems
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
User-Contributed Guide
This guide is not managed by iFixit staff.
Missing Prerequisites
This guide is missing prerequisite guides.
  • Author: Ryan Kuroiwa
  • Time required: 10-15 minutes
  • Difficulty: Easy
  • Add Note x
How to replace the keypad and keypad logic board.
first image
thumb image 1
thumb image 2
  • Depress the silver button.
  • Pull from top of phone to lift the cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Hold battery from both sides at the bottom.
  • Push upwards and gently lift to remove.
first image
Add Note Edit Step 3 — Keypad and Keypad Logic Board  ¶
  • Remove 4 screws from corners using T-6 screwdriver.
  • NOTE: Bottom two screws are gold.
  • NOTE: Make sure screws return to correct place when reassembling.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Use plastic opening tool to pry up back cover from two side clips.
  • NOTE: Sticker might be attached to rest of phone.
first image
Add Note Edit Step 5  ¶
  • Remove the back cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Use a plastic opening tool to gently remove the orange ribbon cable.
  • Lift up the main logic board.
  • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Remove the keypad logic board.
  • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Remove the keypad.
For more information, check out the Motorola V60c device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
