Replacing Garmin Nuvi 200 Display
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Markup Problems
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: Nick
  • Time required: 10 - 15 Minutes
  • Difficulty: Moderate
  • Add Note x
Opening the Nuvi and replacing a broken/damaged display.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Rear Cover  ¶
  • Remove the sticker from the bottom of the device in order to gain access to the two screws behind.
first image
Add Note Edit Step 2  ¶
  • Remove the two screws from the bottom of the case using a T5 Torx screwdriver.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Be careful when opening the nuvi. Using too much force may crack the plastic case.
    • The power switch is held in place by the casing and will come loose once the device is opened. Make sure not to lose the switch.
  • Wedge an iPod opening tool into the seam between the two halves of the plastic case.
  • Apply pressure until the back of the case begins to lift away.
    • There are 2 points that will require pressure on each side of the nuvi.
Next » « Previous
