FujiFilm FinePix A340 LCD Screen Replacement
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: step 1, image 1 of 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: step 2, image 1 of 3 FujiFilm FinePix A340 LCD Screen Replacement: step 2, image 2 of 3 FujiFilm FinePix A340 LCD Screen Replacement: step 2, image 3 of 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: step 3, image 1 of 2 FujiFilm FinePix A340 LCD Screen Replacement: step 3, image 2 of 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: step 5, image 1 of 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: step 6, image 1 of 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: step 7, image 1 of 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: step 8, image 1 of 1
    • Now that everything has been disconnected from the board, remove LCD screen.
Cody
47 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Spring 2010 Member of Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 6,103
