first image
Add Note Edit Step 7  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 8 — Airport Card  ¶
  • Skip this step if your computer does not have an Airport card.
  • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
  • Disconnect the antenna cable from the left side of the Airport card.
first image
Add Note Edit Step 9 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
5mm Nut Driver
$9.95 · 12 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
