Installing PowerBook G4 Titanium Mercury Hard Drive Replacement
Add Note Introduction
You can install hard drives up to 12.5mm thick.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Lower Case
  • Turn the G4 over.
  • Remove the eight Phillips screws from the lower case.
first image
Add Note Step 2
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Step 3
  • Your laptop should look approximately like this.
Notes
There are no notes
