Page 1 of 1
Installing PowerBook G4 Titanium Mercury DVD Drive
- Author: iRobot
- Difficulty: Moderate
How to replace the non-standard DVD drive. Upgrading to a newer drive requires special brackets and cables.
- View:
- Paginated
- Full width
Edit Step 7
DVD Drive
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
Edit Step 10 ¶
Remove the DVD drive by lifting the right edge up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Page 1 of 1
