View profile
Logout
Model M5884 / 400 or 500 MHz G4 processor
« Back to device
Next »
Page 1 of 2
Install an original Airport 802.11b card internally.
With the HTML code below, you can embed this guide as a small widget on your website.
Turn the G4 over.
Remove the eight Phillips screws from the lower case.
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Your laptop should look approximately like this.
Next » « Previous
$4.95 · 50+ in stock
$49.95
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
