Installing PowerBook G4 Titanium DVI Optical Drive
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 3
Easily upgrade to a fast 8x SuperDrive.
Sections
Files
first image
thumb image 1
thumb image 2
  • Locate the battery release tab on the underside of the G4.
  • Slide the battery release tab to the left and lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Remove the seven T8 Torx screws from the lower case.
first image
Add Note Edit Step 3  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Edit Step 4  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 5 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 6  ¶
  • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
first image
Add Note Edit Step 7  ¶
  • Remove the hard drive by lifting the left edge up and out of the computer.
  • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
first image
Add Note Edit Step 8  ¶
first image
Add Note Edit Step 9 — Optical Drive Removal  ¶
  • Disconnect and remove the indicated orange ribbon cable.
first image
Add Note Edit Step 10  ¶
  • Disconnect the pink and white inverter cable from the inverter board.
  • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
first image
Add Note Edit Step 11  ¶
  • Remove the two silver T8 Torx screws from the black plastic bar.
  • Lift the black plastic bar out.
  • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
first image
Add Note Edit Step 12  ¶
  • Disconnect the two orange connectors from the logic board, removing tape as necessary.
first image
Add Note Edit Step 13  ¶
  • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
first image
Add Note Edit Step 14  ¶
  • Remove the drive by lifting the right edge up and out of the computer.
first image
Add Note Edit Step 15 — Optical Drive  ¶
  • Remove the 4 T6 Torx screws securing the modem and inverter boards to the optical drive.
  • Lift the inverter board off of the optical drive.
  • Lift the modem off of the optical drive, carefully guiding the orange cable through the metal mounting bracket.
first image
Add Note Edit Step 16  ¶
  • Disconnect the orange optical drive ribbon from the back of the drive.
first image
Add Note Edit Step 17  ¶
  • If your new optical drive already has a bracket and bezel for your model, then you are done.
  • Remove the 2 Phillips screws from the side with the longer bumper.
  • Remove the bracket from the optical drive.
first image
Add Note Edit Step 18  ¶
  • Remove the 2 Phillips screws from the other side of the optical drive.
first image
Add Note Edit Step 19  ¶
  • Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
  • Remove the 4 Phillips #00 screws from the top of the optical drive.
first image
Add Note Edit Step 20  ¶
  • Lift up on the thinner edge of the optical drive so that you can access and depress the recessed black tab using a spudger.
first image
Add Note Edit Step 21  ¶
  • Use a spudger to depress and release the two black tabs on top of the optical drive directly over the bezel.
first image
Add Note Edit Step 22  ¶
  • Use a spudger to depress and release the black tab on the left side of the optical drive.
first image
Add Note Edit Step 23  ¶
  • Carefully remove the bezel from the optical drive, minding the two plastic tabs on the bottom, which may catch.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
For more information, check out the PowerBook G4 Titanium DVI device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
