Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Step 2 — Lower Case
Remove the seven T8 Torx screws from the lower case.
Step 3
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Notes
There are no notes
