Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM
  • Add Note x
  • x 8
Upgrade your RAM for an instant increase in speed.
Sections
Files
first image
thumb image 1
thumb image 2
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
first image
Add Note Edit Step 2 — Memory Door  ¶
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — RAM  ¶
  • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
  • Pull the RAM chip away from its socket and remove it from the logic board.
  • Repeat this process for the other RAM chip, if present.
For more information, check out the PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
