Installing PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
Restore sound to your laptop by replacing the speakers.
Sections
Files
first image
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
