Step 5
This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
2) After disengaging the locking bar, slide the cable out of the connector.
Step 6
For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
Slide the trackpad cable out of the loosened connector.
When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
Notes
There are no notes
