first image
Add Note Edit Step 13  ¶
  • Disconnect the orange hard drive ribbon from the logic board.
first image
Add Note Edit Step 14  ¶
  • Remove the four T8 (lower right screw is 3.8 mm, the other 3 are 11 mm) Torx screws from the corners of the hard drive bracket.
  • Make sure you're removing the screws from the hard drive bracket, not the hard drive itself.
first image
Add Note Edit Step 15  ¶
  • Deroute hard drive ribbon from beneath the speaker cable.
  • Lift the hard drive and its attached cable out of the computer.
Next » « Previous
For more information, check out the PowerBook G4 Aluminum 17" 1-1.67 GHz device page.
Did you successfully follow this guide?
This guide has been completed 11 times.
