first image
Add Note Edit Step 19  ¶
  • In the following step, the connector you disconnected from the underside of the logic board may catch as you're pulling the card cage out. Of course, the same issue may arise when putting a card cage back into the computer.
  • Hold the PC card cage on the left side and pull it out of the computer.
first image
Add Note Edit Step 20 — Airport Extreme  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 21  ¶
  • Slide the Airport card from the back of the PC card cage.
Next » « Previous
For more information, check out the PowerBook G4 Aluminum 17" 1-1.67 GHz device page.
Did you successfully follow this guide?
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
4mm Nut Driver
$9.95 · 32 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
