first image
Add Note Edit Step 13  ¶
  • Remove the three 4 mm hex nuts using a nut driver or needle-nosed pliers.
first image
Add Note Edit Step 14  ¶
  • Lift the modem partially out of the computer, disconnecting the modem cable before pulling it entirely away.
first image
Add Note Edit Step 15 — PC Card Cage  ¶
  • Place the computer on edge (with the display open).
  • Remove the black bumper and disconnect the Airport Extreme cable beneath it.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
4mm Nut Driver
$9.95 · 32 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
