Installing PowerBook G4 Aluminum 15" 1.67 GHz Hard Drive
Add Note Introduction
Want more storage capacity? Replace your hard drive with a higher capacity unit.
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Upper Case
  • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Step 3
  • Remove the memory compartment cover.
  • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
Add NoteNotes: Step 3
Flag Reply by gepkes Aug 3 2009 @ 11:59 PM
I had 7mm screws here instead of 12mm. Did without them till later.
Flag Reply by Polanskiman Nov 19 2009 @ 9:52 PM
I have an Aluminum PowerBook G4 1.67Ghz since 2006.
3/4 (from bottom to top) of the LCD becomes either black or is jumbled each time I turn on the MAC or move the screen. I need to press the LCD at several locations in order for this problem to go.... any advice ?
