Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
Remove the three 3 mm Phillips screws.
When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
Step 5
Turn the computer 90 degrees clockwise so that the hinge faces you.
Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
Step 6
Rotate the computer 90 degrees clockwise, so that the ports face you.
Don't be hasty! I've seen 2 laptops with a forlorn screw trapped in a video port screwhole, from where it's very difficult, if not impracticable, to remove it.
[quote|colleenthompson]Don't be hasty! I've seen 2 laptops with a forlorn screw trapped in a video port screwhole, from where it's very difficult, if not impracticable, to remove it.[/quote]
I've done that. Was not fun extracting the screw. I had to use a a large speaker magnet to get it out.
[quote|Dan]I've done that. Was not fun extracting the screw. I had to use a a large speaker magnet to get it out.[/quote]
By "bottom", it means the top ones (if the computer were right-side-up), i.e. the ones closer to the lid.
