Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Display
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 10
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Sections
Files
Tools
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
Next » « Previous
