first image
Add Note Step 4
  • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Remove the three 3 mm Phillips screws.
  • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
first image
Add Note Step 5
  • Turn the computer 90 degrees clockwise so that the hinge faces you.
  • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
first image
Add Note Step 6
  • Rotate the computer 90 degrees clockwise, so that the ports face you.
Add NoteNotes: Step 5
Flag Reply by seos Oct 18 2009 @ 5:59 AM
The two "bottom" 5mm philips screws here are the ones closest to the display. (as shown in the image)
