View profile
Logout
« Previous
Page 8 of 8
Make sure you've freed up all four cables attached to the display assembly, and will pull away easily with the rest of the display.
Remove the T8 Torx screw closer to the display on either side of the hinge (two screws total).
Be sure to support the display with one hand while removing the final two screws.
Remove the longer T8 Torx screw remaining on either hinge (two screws total).
Lift the display off.
Next » « Previous
For more information, check out the PowerBook G4 Aluminum 15" 1-1.5 GHz device page.
Oops, I actually didn't do it.
I did it! Success!
$6.95 · 47 in stock
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$2.95 · 16 in stock
$399.95 · 2 in stock
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
