first image
Add Note Step 19
  • Pull the Airport ribbon cable up in order to access the black Airport antenna connector.
  • Disconnect the Airport antenna cable at the black connector, making sure you pull only on the black rubber portion of the connector.
first image
Add Note Step 20
  • Disconnect the inverter cable from the logic board.
first image
Add Note Step 21
  • Remove the two pieces of orange tape covering the display data cable and disconnect the cable from the logic board.
Add NoteNotes: Step 19
Flag Reply by gogreens Nov 11 @ 12:25 PM
my airport antenna cable has no connector and it doesn't run under the Airport ribbon cable, but instead runs under the PCMCIA card slot to god knows where. urgh, am wondering if I'm following the right guide for my g4, 15: 1.5Ghz Pwrbk.
Flag Reply by gogreens Nov 11 @ 5:28 PM
It WAS the right guide, but my machine was missing an Airport cable connector, so I had to remove a half-dozen screws and a nut, loosening some black plastic that was screwed under the modem card, allowing access to remove the PCMCIA receptor (tricky getting it unhooked from the card ejector button), then removing the Airport card in order to unplug the cable.
