first image
Add Note Step 28
  • Disconnect the DC-In connector from the left side of the logic board.
first image
Add Note Step 29
  • Disconnect the battery cable from the front, left corner of the logic board.
first image
Add Note Step 30
  • Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
  • Once the logic board clears the ports, slide it out to the left.
Notes
There are no notes
