Installing PowerBook G4 Aluminum 12" 867 MHz Logic Board
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 7
This motherboard includes all ports except the DC-In board.
Sections
first image
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — EMI Finger  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
4mm Nut Driver
$9.95 · 32 in stock
Coin
$2.95 · 16 in stock
Related Products
$249.95 · 2 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
