Page 1 of 1
Installing PowerBook G4 Aluminum 12" 867 MHz DC-to-DC Board
- Author: iRobot
- Difficulty: Difficult
The DC-to-DC board connects the battery to the computer.
Sections
- Battery 1 step
- EMI Finger 2 steps
- Keyboard 5 steps
- Upper Case 9 steps
- Reed Switch 2 steps
- Hard Drive 3 steps
- DC-to-DC Board 2 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 4
Keyboard
On the keyboard, remove the F1, F2, F11, and F12 keys.
This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
Edit Step 13 ¶
Turn the computer over and open it up.
Remove the following 14 screws:
Six 2.5 mm Phillips on either side of the keyboard area.
Five 4.5 mm Phillips on the left half of the keyboard area.
One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
One 15 mm Phillips in the upper middle of the keyboard area.
One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
Edit Step 14 ¶
Peel up the two pieces of foil tape on the left side of the keyboard area.
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
Edit Step 23
DC-to-DC Board
Remove the following five screws:
One 3 mm Phillips near the screen latch (mind the big magnet on the screen latch).
Two 3.5 mm Phillips attaching the EMI fingers to the metal framework.
One 10 mm Phillips near the optical drive.
One 14 mm long 4 mm standoff in the upper left corner. You can remove this standoff either with a 4 mm nut driver or needlenose pliers.
Lift the EMI fingers above the battery connector away from the metal framework.
Page 1 of 1
