first image
Add Note Edit Step 4 — Keyboard  ¶
  • On the keyboard, remove the F1, F2, F11, and F12 keys.
  • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
  • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
  • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
first image
Add Note Edit Step 5  ¶
  • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
first image
Add Note Edit Step 6  ¶
  • Remove the two short Phillips screws.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
4mm Nut Driver
$9.95 · 32 in stock
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Mini DVI to DVI Adapter
$14.95 · 2 in stock
12.7 mm PATA 8x SuperDrive
$89.95 · 34 in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
Notes Add Note Notes are offturn on
