Installing PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card
Add Note Introduction
Install an Airport Extreme 802.11g card internally.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Airport Extreme Card
  • Flip down the door on the right side of the battery compartment.
first image
Add Note Step 3
  • Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
Add NoteNotes: Step 1
Flag Reply by Gopal 5 days ago
What can I say?
It is certainly do able. I just completed it. Took me 2 hours. The most important tool you'll need is patience - bag full of patience!!
Add NoteNotes: Step 3
Flag Reply by jerrykrinock Jun 13 @ 7:05 AM
Note that this is a "right angle" coaxial connector. The metal cube is a part of the connector and stays with the cable. It is not a part of the airpor card. Also, I found two clear plastic blocks in front of the airport card, a smaller one near the connector and a larger one on the other side. Possibly these are to keep the cable from vibrating and flexing during, say, a truck ride. Don't lose these.
