Installing PowerBook G3 Wallstreet Processor
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 3
The G3 processor is not soldered to the logic board, and installing a replacement is very easy.
Sections
Files
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Remove both expansion bay modules using the levers on the front of the computer.
  • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
  • Pull the tabs toward yourself and the keyboard will pop up.
first image
Add Note Edit Step 2  ¶
  • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
  • Rest the keyboard on the trackpad.
first image
Add Note Edit Step 3  ¶
  • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
  • 2) After disengaging the locking bar, slide the cable out of the connector.
first image
Add Note Edit Step 4  ¶
  • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
first image
Add Note Edit Step 5  ¶
  • Slide a spudger or screwdriver downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
  • Once the strain relief cables are free, lift the keyboard off.
first image
Add Note Edit Step 6  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 7 — Heat Shield  ¶
  • Remove the two Phillips screws from the heat shield.
  • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
first image
Add Note Edit Step 8  ¶
  • Grasp the metal handle on the heat shield and pull up and toward yourself.
first image
Add Note Edit Step 9 — Hard Drive  ¶
  • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
first image
Add Note Edit Step 10  ¶
  • Grasp the hard drive bracket on the left side and pull up and to the left.
first image
Add Note Edit Step 11  ¶
first image
Add Note Edit Step 12 — Processor  ¶
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  • Remove the processor by sliding it up and to the right.
  • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
  • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
For more information, check out the PowerBook G3 Wallstreet device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
