Installing PowerBook G3 Pismo Lower Case
Add Note Introduction
Everything must come out… Then you can replace the bottom case.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Keyboard
  • Turn the keyboard locking screw so that it is parallel to the space bar.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
first image
Add Note Step 2
  • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
  • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
first image
Add Note Step 3
  • Your laptop should look approximately like this.
Notes
There are no notes
