first image
Add Note Edit Step 4 — Heat Shield  ¶
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
first image
Add Note Edit Step 5  ¶
  • Lift the heat shield up and pull it toward you.
first image
Add Note Edit Step 6  ¶
  • Your laptop should look approximately like this.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
