Installing MacBook Unibody Model A1278 Microphone
  • Add Note x
Replacing the microphone in your laptop requires the removal of the logic board.
Sections
first image
Add Note Edit Step 1 — Access Door  ¶
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Edit Step 2  ¶
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Edit Step 3 — Battery  ¶
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the white plastic tab and pull the battery up and out of the Unibody.
first image
Add Note Edit Step 4 — Lower Case  ¶
  • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
first image
Add Note Edit Step 5  ¶
  • Using both hands, lift and remove the lower case off the upper case.
first image
Add Note Edit Step 6 — Mid Wall  ¶
  • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
first image
Add Note Edit Step 7  ¶
  • Lift the mid wall out of the upper case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8 — Fan  ¶
  • Use a spudger to pry the fan connector straight up off the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
first image
Add Note Edit Step 9  ¶
  • Remove the following three screws securing the fan to the upper case:
    • Two 5 mm Phillips screws.
    • One 7 mm Phillips screw.
first image
Add Note Edit Step 10  ¶
  • Lift the fan out of the upper case.
first image
Add Note Edit Step 11 — Logic Board  ¶
  • In the next few steps, you will disconnect the highlighted cables which connect the logic board to the upper case.
  • Each connector is different, so the following steps will show you how disconnect each in detail.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Remove the single Phillips screw securing the battery cable cover to the upper case.
  • Remove the battery cable cover from the upper case.
first image
Add Note Edit Step 13  ¶
  • Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
first image
Add Note Edit Step 14  ¶
  • Disconnect the battery cable connector by pulling it straight away from the logic board.
  • If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
  • Pull the keyboard ribbon cable straight out of its socket.
first image
Add Note Edit Step 16  ¶
  • Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 17  ¶
  • Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
  • Use the tip of a spudger to pull the IR sensor ribbon cable straight away from the logic board.
first image
Add Note Edit Step 18  ¶
  • Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
first image
Add Note Edit Step 19  ¶
  • Use the flat end of a spudger to pry the optical drive cable connector straight up off the logic board.
first image
Add Note Edit Step 20  ¶
  • Disconnect the display data cable by pulling the male end straight away from its socket.
first image
Add Note Edit Step 21  ¶
  • Use the flat end of a spudger to pry the subwoofer cable connector straight up off the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 22  ¶
  • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
  • Pull the display data cable connector straight away from its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 23  ¶
  • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7mm Phillips screw.
    • One 5mm Phillips screw.
  • Remove the two 7 mm Phillips screws from the DC-in board.
  • Lift the display data cable bracket out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 24  ¶
  • If present, remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
  • Lift the bottom case clip out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 25  ¶
  • Remove the two 5mm Phillips screws securing the keyboard flex bracket to the upper case.
  • Lift the keyboard flex bracket out of the upper case.
first image
Add Note Edit Step 26  ¶
  • Use the tip of a spudger to release the microphone from the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 27  ¶
  • Remove the following five screws securing the logic board to the upper case:
    • Four 3mm Phillips screws.
    • One 3.5mm Phillips screw.
  • Lift the logic board from its left edge and pull it out of the upper case.
first image
Add Note Edit Step 28 — Microphone  ¶
  • Deroute the microphone cable from the channel in the left speaker.
first image
Add Note Edit Step 29  ¶
  • Use the flat end of a spudger to pry the microphone cable connector up off the logic board.
For more information, check out the MacBook Unibody Model A1278 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
