Page 1 of 1
MacBook Unibody Model A1278 Logic Board Replacement
- Author: Walter Galan
- Difficulty: Difficult
This motherboard includes all ports on the left side.
Sections
- Access Door 2 steps
- Battery 1 step
- Lower Case 2 steps
- Mid Wall 2 steps
- Fan 3 steps
- Logic Board 17 steps
- Heat Sink 3 steps
- Logic Board Replacement 6 steps
- View:
- Paginated
- Full width
Edit
Step 8
Fan
Use a spudger to pry the fan connector straight up off the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 30
Gently lift the heat sink off the logic board.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Edit
Step 36
After the RAM chip has popped up, pull it straight out of its socket.
Repeat this process if a second RAM chip is installed.
When reinstalling your logic board, don't forget to apply a new layer of thermal paste.
Page 1 of 1
