iFixit
Add Note
Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Optical Drive Replacement
  • Author: iRobot
  • Difficulty: Moderate
Upgrade or replace the SuperDrive.
Sections
Files
View: Paginated Full width Slideshow
first image
Add Note Edit Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield
  • Remove the four identical Phillips screws from the memory door.
first image
Add Note Edit Step 3
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
Parts
Product image
12.7 mm PATA 8x SuperDrive (UJ-875)
$79.95 · 70 in stock
Tools
Tool image
Phillips #00 Screwdriver
$4.95 · 633 in stock
Tool image
T6 Torx Screwdriver
$4.95 · 348 in stock
Tool image
Spudger
$2.95 · 1186 in stock
Popular Repair Guides
Blurb image
Installing iPhone 3GS Headphone...
No audio? Replace the headphone...
79 recent views
Blurb image
Installing iPad 3G Ambient Light...
Replacing the ambient light sensor.
76 recent views
Blurb image
Installing PSP 3000 LCD Screen
Guide for replacing the LCD...
66 recent views
Blurb image
Installing iBook G4 14"...
You can install hard drives up...
54 recent views
Notes Add Note Notes are off | turn on
