Page 1 of 1
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Logic Board Replacement
Replace the motherboard in your MacBook Pro 17" Models A1151 A1212 A1229 and A1261.
- Author: iRobot
- Difficulty: Difficult
This motherboard includes all ports on the right side.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Optical Drive 3 steps
- Logic Board Replacement 10 steps
Tools
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 13
Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Page 1 of 1
