Page 6 of 6
Edit Step 16
Hard Drive Replacement
Remove the two silver T6 Torx screws and white (or black) rubber bumpers from the right side of the hard drive.
You'll need to transfer these screws and bumpers to your new hard drive if you're changing drives. Make sure to put these on the right side of the drive when looking at the label with the SATA connector at the far end.
Edit Step 17 ¶
Remove the two silver T6 Torx screws from the left side of the hard drive (the rubber bumpers remain in the case for the left side of the drive)
You'll need to transfer these screws to your new hard drive if you're changing drives.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
This guide has been completed 237 times.
Page 6 of 6
