first image
Add Note Edit Step 13  ¶
  • Remove the three silver T6 Torx screws securing the right fan to the logic board and lower case.
first image
Add Note Edit Step 14  ¶
  • Hold up the gray and black speaker cable with one hand. Use your other hand to lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Next » « Previous
For more information, check out the MacBook Pro 15" Core Duo Model A1150 device page.
Did you successfully follow this guide?
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
