Installing MacBook Pro 15" Core Duo Model A1150 Right Fan
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 49
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — Memory Door  ¶
  • Remove the three identical Phillips screws from the memory door.
  • Make sure to record which sets of screws came from where. This will help when re-assembling.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
