first image
Add Note Edit Step 16  ¶
  • Disconnect the orange hard drive cable.
  • After installing the new hard drive, make sure the vent hole (on top) is not covered by the orange ribbon cable.
first image
Add Note Edit Step 17 — Hard Drive Replacement  ¶
  • Remove the two silver T6 Torx screws and black rubber bumpers from the right side of the hard drive.
  • You'll need to transfer these screws and bumpers to your new hard drive if you're changing drives.
first image
Add Note Edit Step 18  ¶
  • Remove the two black T6 Torx screws and black rubber bumpers from the left side of the hard drive.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Next » « Previous
For more information, check out the MacBook Pro 15" Core Duo Model A1150 device page.
Did you successfully follow this guide?
This guide has been completed 270 times.
