Installing MacBook Pro 15" Core Duo Bluetooth Antenna
Add Note Introduction
No signal to Bluetooth? Replace the antenna.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Step 2 — Memory Door
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Step 3
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Notes
There are no notes
