Page 1 of 1
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Hard Drive Replacement
- Author: Walter Galan
- Difficulty: Moderate
You can install hard drives up to 9.5mm thick.
Sections
- Battery 1 step
- RAM Shield 1 step
- Upper Case 7 steps
- Hard Drive 2 steps
- Hard Drive Replacement 2 steps
Tools
- View:
- Paginated
- Full width
Edit Step 8 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Edit Step 9 ¶
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal. Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
Remove the upper case.
Edit Step 13 ¶
Remove the two black T6 Torx screws and white rubber bumpers from the right side of the hard drive.
You'll need to transfer these screws and bumpers to your new hard drive if you're changing drives.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Page 1 of 1
