Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Hard Drive Replacement
Add Note Introduction
You can install hard drives up to 9.5mm thick.
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Step 2 — Ram Shield
  • Remove the three identical Phillips screws from the memory door.
  • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
first image
Add Note Step 3 — Upper Case
  • Remove the two Phillips screws in the battery compartment near the latch.
Add NoteNotes: Step 1
Flag Reply by ColmillodeChile Nov 6 2009 @ 1:09 AM
Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
Flag Reply by Adrian Nov 24 2009 @ 3:58 PM
Quote from ColmillodeChile:
What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
Flag Reply by Adrian Nov 24 2009 @ 4:06 PM
Quote from Adrianthomaspre:
Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
Flag Reply by Doug Jan 25 @ 5:15 AM
The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
