Page 1 of 1
Installing MacBook Pro 15" Core 2 Duo Model A1211 Display Assembly
- Author: iRobot
- Difficulty: Moderate
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 9 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
This guide has been completed 6 times.
Page 1 of 1
