Page 1 of 1
Installing MacBook Pro 13" Unibody Mid 2009 Logic Board
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
- Author: Walter Galan
- Difficulty: Moderate
This guide is an internal private guide used as a prereq.
- View:
- Paginated
- Full width
Edit Step 4 ¶
In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
Edit Step 13 ¶
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
Be careful not to rip out the fragile connector plug of the microphone assembly.
Page 1 of 1
