first image
Add Note Edit Step 28  ¶
  • Peel up the silver foil tape from the optical drive.
  • You'll want to reapply this tape in the same position on your replacement drive.
first image
Add Note Edit Step 29  ¶
  • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
  • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
first image
Add Note Edit Step 30  ¶
  • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
  • You'll want to reapply this piece in the same position on your replacement drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Next » « Previous
For more information, check out the MacBook Core Duo device page.
Did you successfully follow this guide?
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Related Products
MacBook/MacBook Pro 15" 8x SuperDrive
$149.95 · 50+ in stock
MacBook 8x SuperDrive (Used)
$199.95 · 5 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
