first image
Add Note Edit Step 58  ¶
  • Remove the two 3.1 mm Phillips screws securing the iSight holder to the top of the display.
  • Make sure to remove the screws securing the metal bracket to the edge of the display and not the screws in the iSight board itself.
first image
Add Note Edit Step 59  ¶
  • Remove the three 3.1 mm Phillips screws along the right edge of the display.
first image
Add Note Edit Step 60  ¶
  • Lift up the LCD panel by its bottom edge and slide it out of the metal mounting brackets.
Next » « Previous
For more information, check out the MacBook Core Duo device page.
Did you successfully follow this guide?
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Plastic Cards
Related Products
MacBook 13.3" LCD Panel
$149.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
