View profile
Logout
« Previous
Next »
Page 2 of 20
Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
The shorter of the three screws goes in the middle.
Remove the following 3 screws from the rear wall of the battery compartment:
Two 3 mm Phillips #00.
One 4 mm Phillips #00 on the right side.
When reinstalling these screws, it may be helpful to push down on the lower case to line up the screw holes.
Next » « Previous
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$2.95 · 16 in stock
$149.95 · 50+ in stock
$19.95
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$7.95 · 13 in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
