first image
thumb image 1
thumb image 2
Add Note Edit Step 46  ¶
  • Use a spudger to slide the right bezel cover toward the LCD panel.
  • Lift the right bezel cover off the display assembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 47  ¶
  • Lift the inverter out of the display slightly and disconnect the backlight cable from its right side.
  • Place the inverter back down in its recess.
first image
Add Note Edit Step 48  ¶
  • Remove the single 3.2 mm Phillips screw securing the display data cable to the right clutch hinge.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Plastic Cards
Related Products
MacBook 13.3" LCD Panel
$149.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
