first image
Add Note Step 43
  • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift the clutch cover out of the display assembly.
  • Make sure not to pinch the pink and white inverter cable when snapping the clutch cover back into place.
first image
Add Note Step 44 — Inverter
  • Lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board.
first image
Add Note Step 45
  • Disconnect the white inverter cable from the right end of the inverter board.
Add NoteNotes: Step 45
Flag Reply by pdofoto Aug 3 @ 12:25 PM
The white connector will stop once before it goes all the way in.... so feel for one "soft stop", and then another push and you should feel a positive snap.
If this is not connected properly the backlight will not work.
