first image
Add Note Edit Step 37  ¶
  • Next, free the five tabs securing the display bezel on the right side.
first image
thumb image 1
thumb image 2
Add Note Edit Step 38  ¶
  • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
  • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
  • After freeing all holding tabs, lift the front display bezel away from the display assembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 39  ¶
  • Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
  • Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel.
  • Be careful, as the clips are made of thin plastic and are inherently delicate.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Plastic Cards
Related Products
MacBook Front Display Bezel
$29.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
