first image
Add Note Step 25
  • Lift the right speaker out of its housing and set it to the side.
first image
Add Note Step 26
  • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
first image
Add Note Step 27 — Display
  • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
  • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
Add NoteNotes: Step 26
Flag Reply by zsadler13 Mar 26 @ 6:42 PM
c-channel is missing
iFixit Staff
Flag Reply by Brady Cabe Apr 1 @ 2:27 PM
Quote from zsadler13:
Your computer is missing the c-channel?
iFixit Staff
Flag Reply by Brady Cabe Apr 1 @ 3:06 PM
Quote from brady:
This guide is for the Core Duo MacBook, you may be referring to the Penryn/Santa Rosa MacBook which does not have the c-channel.
Add NoteNotes: Step 27
Flag Reply by mikacooper Apr 9 @ 6:29 PM
VERY IMPORTANT!!!! The plug backs out of its jack along the plane of the logic board, away from the front of the computer, toward the screen. YOU DO NOT PULL IT STRAIGHT UP FROM THE BOARD! The photo is ambiguous, and I ended up ripping away from the logic board the jack the microphone cable plugs into. I doubt I'll be able to solder it back on again, so bye-bye internal mic.
